Introduzione
This guide will demonstrate how to replace the Battery Case inside the Wii Balance Board.
Flip device upside-down so the plastic white board is facing the ground.
  • Flip device upside-down so the plastic white board is facing the ground.
  • Locate the four feet in the corners of the Balance Board.
  • Unscrew the three 12.7 mm Philips screws from each foot cover.
Aggiungi Commento
Remove the grey plastic ring from the actual foot by lifting it up.
  • Remove the grey plastic ring from the actual foot by lifting it up.
Aggiungi Commento
Separate the loose foot from the device by lifting it up.
  • Separate the loose foot from the device by lifting it up.
Aggiungi Commento
Repeat steps two and three on the remaining four feet.
  • Repeat steps two and three on the remaining four feet.
Aggiungi Commento
Unscrew the ten 12.7 mm #1 screws.
  • Unscrew the ten 12.7 mm #1 screws.
Aggiungi Commento
Lift off the gray back cover.
  • Lift off the gray back cover.
Aggiungi Commento
Locate the grey battery compartment. Push the tab on the bottom and lift up completely to remove the cover to the batteries.
  • Locate the grey battery compartment.
  • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
Aggiungi Commento
Unscrew the two 6.35 mm #1 screws.
  • Unscrew the two 6.35 mm #1 screws.
  • Slide the battery case out.
Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
Michelle Reed
Membro da: 29/09/2014
304 Reputazione
1 Guida realizzata
Cal Poly, Team 13-8, Forte Fall 2014 Membro di Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Membri
5 Guide realizzate
I unscrewed everything, but were do i find a replacement battery compartent?
Olivia C - Replica
Then what do you do after you remove the battery case?
CRAIG WIKMAN - Replica
Is there a way to open the top of the board by sliding or lifting the top? I bought a gently used wii fit. The lady who sold it to me very quickly opened the top of the board from the centre seam to show me the instruction manual and I think hook up cables. I cannot, for the life of me figure out how she did it! Any ideas or technical wizardry you can share?
Frustrated in Canada!
Pam Murray - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 139
Tutti i Tempi: 13,531
