Introduzione
Battery replacement is recommended every 300 charge cycles. Use this guide to replace the battery in your 6000 series Welch Allyn Connex Vital Signs Monitor.
PLEASE NOTE: This repair guide was developed by the iFixit team based on Welch Allyn's own service manual. Neither iFixit nor this repair guide is endorsed by or affiliated with Welch Allyn.
Unplug the AC power connection cable. Unplug the AC power connection cable.
  • Unplug the AC power connection cable.
Aggiungi Commento
Place your thumb and forefinger on the blood pressure (NIBP) hose connector. Squeeze the side tabs until the connector releases. Always grasp the hose by the connector. Do not pull on the hose itself. Pull the connector away from the connector port.
  • Place your thumb and forefinger on the blood pressure (NIBP) hose connector. Squeeze the side tabs until the connector releases.
    • Always grasp the hose by the connector. Do not pull on the hose itself.
  • Pull the connector away from the connector port.
Aggiungi Commento
Place your thumb and forefinger on the Pulse oximetry (SpO2 or combined SpO2/SpHb) cable connector. Squeeze the side tabs until the connector releases. Always grasp the cable by the connector. Do not pull on the cable itself. Pull the connector away from the connector port.
  • Place your thumb and forefinger on the Pulse oximetry (SpO2 or combined SpO2/SpHb) cable connector. Squeeze the side tabs until the connector releases.
    • Always grasp the cable by the connector. Do not pull on the cable itself.
Aggiungi Commento
Grasp the temperature probe and pull it up to remove it from the monitor. Grasp the temperature probe and pull it up to remove it from the monitor.
  • Grasp the temperature probe and pull it up to remove it from the monitor.
Aggiungi Commento
Remove the cover of the temperature module by pressing the tab and sliding the cover to the right. Remove the cover of the temperature module by pressing the tab and sliding the cover to the right. Remove the cover of the temperature module by pressing the tab and sliding the cover to the right.
  • Remove the cover of the temperature module by pressing the tab and sliding the cover to the right.
Aggiungi Commento
Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port. Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port. Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port.
  • Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port.
Aggiungi Commento
Remove the flathead screw on the USB networking door.
  • Remove the flathead screw on the USB networking door.
  • Loosen the captive Phillips #2 screw securing the monitor to the stand.
Aggiungi Commento
Holding the monitor securely, open the USB networking door.
  • Holding the monitor securely, open the USB networking door.
    • You may have to lift the monitor slightly to allow the door to swing out from the stand mount.
Aggiungi Commento
Detach any accessory USB cables from USB ports on the monitor. Detach any accessory USB cables from USB ports on the monitor.
  • Detach any accessory USB cables from USB ports on the monitor.
Aggiungi Commento
Slide the monitor off of the stand tray. Slide the monitor off of the stand tray. Slide the monitor off of the stand tray.
  • Slide the monitor off of the stand tray.
Aggiungi Commento
Place the monitor upside down on a clean surface. Insert a coin into the slot and push to open. Choose a coin that fits comfortably into the slot.
  • Place the monitor upside down on a clean surface.
  • Insert a coin into the slot and push to open.
    • Choose a coin that fits comfortably into the slot.
  • Remove the battery cover.
Aggiungi Commento
Use the plastic label to remove the battery from its recess. Use the plastic label to remove the battery from its recess. Use the plastic label to remove the battery from its recess.
  • Use the plastic label to remove the battery from its recess.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
kyle2
Membro da: 03/06/2010
101 Reputazione
1 Guida realizzata
Team Freedom Membro di Team Freedom
Community
1 Membro
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 16
Tutti i Tempi: 895
