Introduzione
The hot plate is held in place by multiple screws along the burner ring and electrical wires. When free from the frame, take care when removing the iron plate itself as it is fairly dense.
Parti
Nessuna parte richiesta.
Remove the screws on the back panel with the #1 Phillips screwdriver bit.
  • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
    • The screws in the rubber legs of the burner do not need to be removed.
    • If the back panel has never been opened before, the screws may be more difficult to unscrew.
Aggiungi Commento
Using a wrench, remove the bolt from the center of the back panel. Using a wrench, remove the bolt from the center of the back panel.
  • Using a wrench, remove the bolt from the center of the back panel.
Aggiungi Commento
The back panel can now be easily lifted off.
  • The back panel can now be easily lifted off.
Aggiungi Commento
Remove screws #1 Phillips screwdriver bit. The interior edges of the metal frame are sharp and can cause minor cuts.
  • Remove screws #1 Phillips screwdriver bit.
    • The interior edges of the metal frame are sharp and can cause minor cuts.
    • 3 screws on the perimeter of the circle
    • 1 screw in the circle
    • 2 screws on the eletrical stands with wires
Aggiungi Commento
Remove rod from the center of the plate with a wrench. Remove rod from the center of the plate with a wrench.
  • Remove rod from the center of the plate with a wrench.
Aggiungi Commento
Remove plate carefully as to not damage internal components i.e. insulator, metal frame, wires, etc. Remove plate carefully as to not damage internal components i.e. insulator, metal frame, wires, etc.
  • Remove plate carefully as to not damage internal components i.e. insulator, metal frame, wires, etc.
Aggiungi Commento
Conclusione
Sun Fai Lau
Membro da: 22/09/2014
513 Reputazione
5 Guide realizzate
USF Tampa, Team 10-7, Brown Fall 2014 Membro di USF Tampa, Team 10-7, Brown Fall 2014
USFT-BROWN-F14S10G7
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 798
