Salta al contenuto principale
VuPoint DC-ST210-VP Battery Door Cover Replacement
Cosa ti serve
  1. VuPoint DC-ST210-VP Battery Door Cover Replacement, Turn Off/Remove Batteries: passo 1, immagine 1 di 1
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: passo 2, immagine 1 di 3 VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: passo 2, immagine 2 di 3 VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: passo 2, immagine 3 di 3
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. VuPoint DC-ST210-VP Battery Door Cover Replacement, Pry Backplate Off: passo 3, immagine 1 di 2 VuPoint DC-ST210-VP Battery Door Cover Replacement, Pry Backplate Off: passo 3, immagine 2 di 2
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Battery Case Screw: passo 4, immagine 1 di 1
    • Remove the 4.5mm screw with the iFixit ph#00 screwdriver
  5. VuPoint DC-ST210-VP Battery Door Cover Replacement, Open the Battery Case: passo 5, immagine 1 di 2 VuPoint DC-ST210-VP Battery Door Cover Replacement, Open the Battery Case: passo 5, immagine 2 di 2
    • With your fingers, gently pull the two pieces of the battery case apart. At this point, the battery door should be exposed
  6. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove the Battery Cover: passo 6, immagine 1 di 1
    • With your fingers, gently remove the battery door.
    • Now you are free to repair or replace the battery door! Follow these steps in reverse order to reassemble the camera.
Conclusione
Altre 2 persone hanno completato questa guida.
Elise Brown
Membro da: 10/26/14
70 Reputazione
2 Guide realizzate
Baylor, Team 8-15, Williams Fall 2014 Membro di Baylor, Team 8-15, Williams Fall 2014
BU-WILLIAMS-F14S8G15
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 359
