Salta al contenuto principale
Visioneer OneTouch 7400 USB Scanner Bed Replacement
Cosa ti serve
  1. Visioneer OneTouch 7400 USB Scanner Bed Replacement, Outer Case: passo 1, immagine 1 di 1
    • On the bottom of the scanner, remove the screw at the top left side.
  2. Visioneer OneTouch 7400 USB Scanner Bed Replacement: passo 2, immagine 1 di 2 Visioneer OneTouch 7400 USB Scanner Bed Replacement: passo 2, immagine 2 di 2
    • Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
    • Remove the screw beneath the foot-pad.
  3. Visioneer OneTouch 7400 USB Scanner Bed Replacement: passo 3, immagine 1 di 3 Visioneer OneTouch 7400 USB Scanner Bed Replacement: passo 3, immagine 2 di 3 Visioneer OneTouch 7400 USB Scanner Bed Replacement: passo 3, immagine 3 di 3
    • Rotate the scanner so the screw hole is located on the top left hand side.
    • Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
    • Gently pry the two casements apart beginning above the screw hole and working your way around.
    • Note that the top and bottom casings are held together by a series of 6 tabs. There is one tab on each of the long sides of the scanner approximately 6 inches in from the corners. There are two tabs on each of the short sides of the scanner approximately 2.3 inches in from the corners. Use the spudger to unhook the tab from the top casement.
  4. Visioneer OneTouch 7400 USB Scanner Bed Replacement: passo 4, immagine 1 di 1
    • Separate the two casement pieces.
  5. Visioneer OneTouch 7400 USB Scanner Bed Replacement, Scanner Bed: passo 5, immagine 1 di 1
    • Apply even pressure against the back of the glass while securing the plastic frame in place.
  6. Visioneer OneTouch 7400 USB Scanner Bed Replacement: passo 6, immagine 1 di 2 Visioneer OneTouch 7400 USB Scanner Bed Replacement: passo 6, immagine 2 di 2
    • With consistent pressure on the glass, move your fingers down the sides until the glass is no longer stuck to the double-sided tape.
Conclusione
Jena
Membro da: 10/18/13
608 Reputazione
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 282
