Introduzione
Use this guide to remove and replace the Visioneer OneTouch 7400 USB scanner motor.
Parti
Nessuna parte richiesta.
On the bottom of the scanner, remove the screw at the top left side.
  • On the bottom of the scanner, remove the screw at the top left side.
Aggiungi Commento
Remove the rubber foot pad opposite the screw hole to expose a second screw hole. Remove the screw beneath the foot-pad.
  • Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
  • Remove the screw beneath the foot-pad.
Aggiungi Commento
Rotate the scanner so the screw hole is located on the top left hand side. Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up. Gently pry the two casements apart beginning above the screw hole and working your way around.
  • Rotate the scanner so the screw hole is located on the top left hand side.
  • Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
  • Gently pry the two casements apart beginning above the screw hole and working your way around.
  • Note that the top and bottom casings are held together by a series of 6 tabs. There is one tab on each of the long sides of the scanner approximately 6 inches in from the corners. There are two tabs on each of the short sides of the scanner approximately 2.3 inches in from the corners. Use the spudger to unhook the tab from the top casement.
Aggiungi Commento
Separate the two casement pieces.
  • Separate the two casement pieces.
Aggiungi Commento
Carefully detach the wires from the motherboard, pulling slowly but firmly.
  • Carefully detach the wires from the motherboard, pulling slowly but firmly.
Aggiungi Commento
Remove the four screws holding the motor in place. Note: the pictures hereafter shown are without the motherboard, but you do not have to remove the motherboard to access the motor.
  • Remove the four screws holding the motor in place.
    • Note: the pictures hereafter shown are without the motherboard, but you do not have to remove the motherboard to access the motor.
Aggiungi Commento
Lift the motor out of the scanner.
  • Lift the motor out of the scanner.
Aggiungi Commento
Conclusione
Jena
Membro da: 18/10/2013
608 Reputazione
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 121
