Introduzione
Please ensure you have followed the prerequisite guide of removing the battery before proceeding with this guide.
Parti
Nessuna parte richiesta.
To remove the back panel, first press and hold the gray button on the back. While doing that also press and slide the panel down and off. To remove the back panel, first press and hold the gray button on the back. While doing that also press and slide the panel down and off.
  • To remove the back panel, first press and hold the gray button on the back. While doing that also press and slide the panel down and off.
Aggiungi Commento
Carefully remove the battery from the phone by prying it from the top.
  • Carefully remove the battery from the phone by prying it from the top.
Aggiungi Commento
With the opening tool, remove the rubber plugs from the screw holes around the screen.
  • With the opening tool, remove the rubber plugs from the screw holes around the screen.
Aggiungi Commento
With a Philips screwdriver, remove the four screws from around the phone's screen.
  • With a Philips screwdriver, remove the four screws from around the phone's screen.
Aggiungi Commento
Pry the top cover off the phone with a plastic opening tool.
  • Pry the top cover off the phone with a plastic opening tool.
Aggiungi Commento
Remove the screen assembly from the phone.
  • Remove the screen assembly from the phone.
Aggiungi Commento
With the opening tool, pry the circuit board off of the screen.
  • With the opening tool, pry the circuit board off of the screen.
Aggiungi Commento
Conclusione
Corey Ryman
Membro da: 14/10/2011
255 Reputazione
8 Guide realizzate
James Madison, Team 2-4, Allen Fall 2011 Membro di James Madison, Team 2-4, Allen Fall 2011
JMU-ALLEN-F11S2G4
3 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 929
