Introduzione
To replace the refresh button, you will need to open the router's outer casings. This replacement is simple and will not take much time to complete.
Parti
Nessuna parte richiesta.
Flip the device so that the bottom is facing up.
  • Flip the device so that the bottom is facing up.
Aggiungi Commento
Insert the plastic-opening tool under the silver labeled casing. Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing. Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
  • Insert the plastic-opening tool under the silver labeled casing.
  • Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
Aggiungi Commento
Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver. Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
  • Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
Aggiungi Commento
Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device. Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
  • Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
Aggiungi Commento
Locate the refresh button.
  • Locate the refresh button.
Aggiungi Commento
Apply pressure with your finger to the black tab that retains the refresh button while using your other hand to pull the bottom of the refresh button from the post. Apply pressure with your finger to the black tab that retains the refresh button while using your other hand to pull the bottom of the refresh button from the post. Apply pressure with your finger to the black tab that retains the refresh button while using your other hand to pull the bottom of the refresh button from the post.
  • Apply pressure with your finger to the black tab that retains the refresh button while using your other hand to pull the bottom of the refresh button from the post.
Aggiungi Commento
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 208
