Introduzione
In this guide, you will learn how to remove and install the speaker of your alarm clock. The process consists of removing the front screen, followed by taking the hardware out of the housing and detaching the power cord. The next step consists of removing the top plastic from the motherboard, being sure to not fully remove the two. You would then take the speaker in the plastic frame and gently pop it out of its housing.
Cosa ti serve
On the bottom of the clock locate and unscrew the single 2mm Phillips screw from bottom of the clock.
Get a firm grip on the outside of the clock and a firm grip on the hardware on the inside of the the clock like so and pull the hardware out from the outside of the clock.
Just as before, pull the speaker plug directly up to remove the plug from the motherboard.
Flip over the motherboard and grab hold of the plastic frame.
With a small amount of force, push on the plastic clips, away from you, to eject the speaker from its plastic housing.
