Salta al contenuto principale
Velocity NoteMagix M10 A82 Hard Drive Replacement
Cosa ti serve
  1. Velocity NoteMagix M10 A82 Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 Velocity NoteMagix M10 A82 Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Velocity NoteMagix M10 A82 Hard Drive Replacement: passo 2, immagine 1 di 2 Velocity NoteMagix M10 A82 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
  3. Velocity NoteMagix M10 A82 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 2 Velocity NoteMagix M10 A82 Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 2
    • Unscrew the two 3.65mm Phillips #1 screws on the plate marked "HDD".
  4. Velocity NoteMagix M10 A82 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Lift the HDD plate off of the back to reveal the hard drive.
  5. Velocity NoteMagix M10 A82 Hard Drive Replacement: passo 5, immagine 1 di 2 Velocity NoteMagix M10 A82 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Use the spudger to push the area above the connector on the hard drive to the right.
    • Lift the hard drive gently from the computer with the spudger.
Conclusione
Sam Middleton
Membro da: 10/01/13
401 Reputazione
4 Guide realizzate
Cal Poly, Team 14-9, Forte Fall 2013 Membro di Cal Poly, Team 14-9, Forte Fall 2013
CPSU-FORTE-F13S14G9
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 297
