Introduzione
This guide will show how to safely remove the cooling fan from the NoteMagix M10 A82 netbook.
Place the notebook on the table, with the battery facing away from you. Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
  • Place the notebook on the table, with the battery facing away from you.
  • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
  • Maintain holding the right switch in the "unlock" position.
  • Use your left hand to slide the left switch from "lock" to "unlock".
Aggiungi Commento
Maintain both left and right switches in the "unlock" position. Use your forefingers to push the battery out of the computer.
  • Maintain both left and right switches in the "unlock" position.
  • Use your forefingers to push the battery out of the computer.
Aggiungi Commento
Place the laptop fully opened with the keyboard facing upwards.
  • Place the laptop fully opened with the keyboard facing upwards.
  • Remove the hinge cover by wedging the spudger underneath at the bottom edge and gently prying upwards while sliding the spudger along the cover.
Aggiungi Commento
Carefully remove the keyboard by lifting the top of the keyboard closest to the screen.
  • Carefully remove the keyboard by lifting the top of the keyboard closest to the screen.
  • Pull the keyboard away from the mousepad.
  • Be careful to not damage the ribbon underneath the keyboard that connects the keyboard to the computer during removal.
Aggiungi Commento
Wedge the spudger between the plastic clamp that holds the ribbon in place and carefully pry the connector off.
  • Wedge the spudger between the plastic clamp that holds the ribbon in place and carefully pry the connector off.
Aggiungi Commento
Remove the eight 5.65mm Phillips #1 screws.
  • Remove the eight 5.65mm Phillips #1 screws.
Aggiungi Commento
Place the computer open and with the screen facing up on the table.
  • Place the computer open and with the screen facing up on the table.
  • Remove the three 3.65mm Phillips #1 screws in the right hand corner. Also remove the mirrored set of screws on the left side.
Aggiungi Commento
Remove the black and gray wires by gently grasping the wires where they connect to the motherboard and pulling up.
  • Remove the black and gray wires by gently grasping the wires where they connect to the motherboard and pulling up.
Aggiungi Commento
Using the plastic opening tool, pry the base of the cable connecting the screen to the motherboard upwards.
  • Using the plastic opening tool, pry the base of the cable connecting the screen to the motherboard upwards.
Aggiungi Commento
Remove the front cover plate by wedging the spudger underneath at the bottom edge of the computer and gently prying upwards while sliding the spudger around the base of the laptop. Remove the front cover plate by wedging the spudger underneath at the bottom edge of the computer and gently prying upwards while sliding the spudger around the base of the laptop.
  • Remove the front cover plate by wedging the spudger underneath at the bottom edge of the computer and gently prying upwards while sliding the spudger around the base of the laptop.
Aggiungi Commento
Remove the two 4.80mm Phillips #00 screws holding down the fan.
  • Remove the two 4.80mm Phillips #00 screws holding down the fan.
Aggiungi Commento
Remove the red, yellow, and black wires connecting the fan to the motherboard by placing your index finger underneath the wires where they connect to the motherboard, pinching the wires together with your thumb and index finger, and gently pulling the wires upwards. Remove the red, yellow, and black wires connecting the fan to the motherboard by placing your index finger underneath the wires where they connect to the motherboard, pinching the wires together with your thumb and index finger, and gently pulling the wires upwards.
  • Remove the red, yellow, and black wires connecting the fan to the motherboard by placing your index finger underneath the wires where they connect to the motherboard, pinching the wires together with your thumb and index finger, and gently pulling the wires upwards.
Aggiungi Commento
Conclusione
Jaymes Lee
Membro da: 17/08/2012
101 Reputazione
1 Guida realizzata
Cal Poly, Team 14-9, Forte Fall 2013 Membro di Cal Poly, Team 14-9, Forte Fall 2013
CPSU-FORTE-F13S14G9
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 307
