Introduzione
In this guide, you will learn how to uninstall programs from your HTC Fortress.
With the phone powered on and at the home screen, tap "Start".
  • With the phone powered on and at the home screen, tap "Start".
Aggiungi Commento
Tap "Settings".
  • Tap "Settings".
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Tap "System".
  • Tap "System".
Aggiungi Commento
Tap "Remove Programs".
  • Tap "Remove Programs".
Aggiungi Commento
Your installed applications will be listed here. Simply highlight the application you want to remove and tap "Remove".
  • Your installed applications will be listed here. Simply highlight the application you want to remove and tap "Remove".
Aggiungi Commento
Conclusione
The application will now be uninstalled from your phone.
Lucas David
Membro da: 19/04/2013
523 Reputazione
9 Guide realizzate
Cal Poly, Team 4-13, Maness Spring 2013 Membro di Cal Poly, Team 4-13, Maness Spring 2013
CPSU-MANESS-S13S4G13
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 486
