Salta al contenuto principale
Uniden TCX905 Back Speaker Replacement
Cosa ti serve
  1. Uniden TCX905 Back Speaker Replacement, Battery Cover: passo 1, immagine 1 di 2 Uniden TCX905 Back Speaker Replacement, Battery Cover: passo 1, immagine 2 di 2
    • Starting from the top of the cover, slide down and away from the phone with your thumb
    • Lift battery cover off of batter and place it to the side
  2. Uniden TCX905 Back Speaker Replacement, Battery Pack: passo 2, immagine 1 di 2 Uniden TCX905 Back Speaker Replacement, Battery Pack: passo 2, immagine 2 di 2
    • Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
    • Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
    • Place battery pack to the side
  3. Uniden TCX905 Back Speaker Replacement, Back Shell: passo 3, immagine 1 di 2 Uniden TCX905 Back Speaker Replacement, Back Shell: passo 3, immagine 2 di 2
    • Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
  4. Uniden TCX905 Back Speaker Replacement: passo 4, immagine 1 di 3 Uniden TCX905 Back Speaker Replacement: passo 4, immagine 2 di 3 Uniden TCX905 Back Speaker Replacement: passo 4, immagine 3 di 3
    • Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
  5. Uniden TCX905 Back Speaker Replacement: passo 5, immagine 1 di 3 Uniden TCX905 Back Speaker Replacement: passo 5, immagine 2 di 3 Uniden TCX905 Back Speaker Replacement: passo 5, immagine 3 di 3
    • Ensure that wired connection between circuit board and back shell is not strained
    • Fold the back shell underneath the front shell and circuit board
  6. Uniden TCX905 Back Speaker Replacement, Back Speaker: passo 6, immagine 1 di 2 Uniden TCX905 Back Speaker Replacement, Back Speaker: passo 6, immagine 2 di 2
    • Lay the back shell with the inside facing up
    • To remove the speaker guard, first remove the 7mm screw from inside the back shell
  7. Uniden TCX905 Back Speaker Replacement: passo 7, immagine 1 di 3 Uniden TCX905 Back Speaker Replacement: passo 7, immagine 2 di 3 Uniden TCX905 Back Speaker Replacement: passo 7, immagine 3 di 3
    • To access the speaker, flip the back shell over and use a plastic opening tool to pop open the black cover
    • Gently push the speaker guard out of place with your thumb
    • Carefully slide the speaker out from its setting and place speaker guard aside
  8. Uniden TCX905 Back Speaker Replacement: passo 8, immagine 1 di 2 Uniden TCX905 Back Speaker Replacement: passo 8, immagine 2 di 2
    • With speaker exposed, remove the speaker by cutting the red and black wires near their contact location
Conclusione
Gary Pence
Membro da: 03/26/14
807 Reputazione
8 Guide realizzate
Clemson, Team 1-1, Benson Spring 2014 Membro di Clemson, Team 1-1, Benson Spring 2014
CLEM-BENSON-S14S1G1
3 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 345
