Salta al contenuto principale
Uniden EXP 371 Charging Contact Points Replacement
Cosa ti serve
  1. Uniden EXP 371 Charging Contact Points Replacement, Charging Contact Points: passo 1, immagine 1 di 2 Uniden EXP 371 Charging Contact Points Replacement, Charging Contact Points: passo 1, immagine 2 di 2
    • Your first step will be to remove the battery cover and the battery.
  2. Uniden EXP 371 Charging Contact Points Replacement: passo 2, immagine 1 di 1
    • The next step will be to remove the two screws from the rear of the phone case.
  3. Uniden EXP 371 Charging Contact Points Replacement: passo 3, immagine 1 di 1
    • After that you will need to pry the back of the case off of the front part of the case.
  4. Uniden EXP 371 Charging Contact Points Replacement: passo 4, immagine 1 di 2 Uniden EXP 371 Charging Contact Points Replacement: passo 4, immagine 2 di 2
    • After removing the rear cover there will be two more screws to remove that hold each of the charging contact points. Once those are removed you can replace them with the new ones.
    • When replacing the charging contacts, they only go on one way, but it is useful to note how the original ones were on.
    • Reverse these steps in order to reassemble your phone.
Conclusione
UMass Dartmouth, Team 2-1, Duarte Fall 2014 Membro di UMass Dartmouth, Team 2-1, Duarte Fall 2014
UMASSD-DUARTE-F14S2G1
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 153
