Introduzione
Follow this guide to properly replace the speaker.
Push the highlighted button in the direction in which the antenna is pointing. The battery will release and pop up.
  • Push the highlighted button in the direction in which the antenna is pointing. The battery will release and pop up.
Aggiungi Commento
Remove the battery.
  • Remove the battery.
Aggiungi Commento
Identify the antenna. It is the extendable plastic component pictured here.
  • Identify the antenna. It is the extendable plastic component pictured here.
Aggiungi Commento
Twist the base in a counter-clockwise motion to unscrew the antenna.
  • Twist the base in a counter-clockwise motion to unscrew the antenna.
Aggiungi Commento
The antenna should slide right out of the phone when finished. The antenna should slide right out of the phone when finished.
  • The antenna should slide right out of the phone when finished.
Aggiungi Commento
Remove the small rubber grommet using a plastic opening tool as shown.
  • Remove the small rubber grommet using a plastic opening tool as shown.
Aggiungi Commento
Unscrew all five of the highlighted screws using a Phillips #00 Screwdriver.
  • Unscrew all five of the highlighted screws using a Phillips #00 Screwdriver.
Aggiungi Commento
Use a plastic opening tool to separate the two pieces that form the outer case of the phone.
  • Use a plastic opening tool to separate the two pieces that form the outer case of the phone.
  • Caution: prying the two pieces apart may be difficult.
Aggiungi Commento
Remove the posterior piece of the outer case.
  • Remove the posterior piece of the outer case.
Aggiungi Commento
Remove the speaker using a plastic opening tool.
  • Remove the speaker using a plastic opening tool.
Aggiungi Commento
Remove the wire attached to the speaker from the logic board using tweezers. Remove the wire attached to the speaker from the logic board using tweezers.
  • Remove the wire attached to the speaker from the logic board using tweezers.
Aggiungi Commento
Conclusione
Eli
Membro da: 27/09/2012
1 Reputazione
2 Guide realizzate
Cal Poly, Team 24-26, Regan Fall 2012 Membro di Cal Poly, Team 24-26, Regan Fall 2012
CPSU-REGAN-F12S24G26
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 275
