Introduzione
The extrusion head fan keeps the assembly piece cool and free of debris for continued printing. Before starting this replacement you will need to remove the plastic cover. You will need a hex wrench and a small Phillip's head screwdriver. Be sure you are careful when removing the fan, because it is a thin plastic that is easily breakable.
Parti
Nessuna parte richiesta.
Remove the plastic cover that sits on the extruder, next to the fan, by lifting the latches in the back. The latches should lift right out. Remove the plastic cover that sits on the extruder, next to the fan, by lifting the latches in the back. The latches should lift right out.
  • Remove the plastic cover that sits on the extruder, next to the fan, by lifting the latches in the back. The latches should lift right out.
Aggiungi Commento
Using the Phillips #0 screwdriver, locate and remove the two 3mm screws on the top of the fan using a counter-clockwise rotation. Using the Phillips #0 screwdriver, locate and remove the two 3mm screws on the top of the fan using a counter-clockwise rotation.
  • Using the Phillips #0 screwdriver, locate and remove the two 3mm screws on the top of the fan using a counter-clockwise rotation.
Aggiungi Commento
Locate the fan connector, a 2-pin JST type, from the extruder board on the top of the extruder assembly and while firmly holding the plastic part of the connector, wiggle out the wire. Gently lift the fan off and away from the module. The fan should easily fall out.
  • Locate the fan connector, a 2-pin JST type, from the extruder board on the top of the extruder assembly and while firmly holding the plastic part of the connector, wiggle out the wire.
  • Gently lift the fan off and away from the module. The fan should easily fall out.
Aggiungi Commento
Place the replacement fan on the extruder assembly in the right orientation. Connect the cable make sure that it has a solid connection.
  • Place the replacement fan on the extruder assembly in the right orientation.
  • Connect the cable make sure that it has a solid connection.
    • The fins of the fan should be directed to blow torwards the hot extruder shown in the picture, not away.
  • Secure the fan by screwing the top screws back into place in a clockwise rotation.
  • Finish by putting the plastic top back on.
Aggiungi Commento
Conclusione
valerie boyer
Membro da: 12/10/2014
460 Reputazione
4 Guide realizzate
Cal Poly, Team 14-31, Maness Fall 2014 Membro di Cal Poly, Team 14-31, Maness Fall 2014
CPSU-MANESS-F14S14G31
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 471
