Introduzione
The windscreen is designed to prevent dust and moisture from getting into the microphone. It is held onto the microphone by a single 0.4 cm long Phillips head screw attached by a mounting bracket. Due to its fragile design, the windscreen can easily be torn, but it can quickly be replaced with the help of this guide.
Parti
Nessuna parte richiesta.
First remove the microphone from the headset. Pull gently on the end of the microphone where it attaches to the headset. First remove the microphone from the headset. Pull gently on the end of the microphone where it attaches to the headset.
  • First remove the microphone from the headset. Pull gently on the end of the microphone where it attaches to the headset.
Aggiungi Commento
Using a Philips #0 screwdriver, unscrew the 4-mm-long screw that attaches the windscreen to the microphone. Using a Philips #0 screwdriver, unscrew the 4-mm-long screw that attaches the windscreen to the microphone.
  • Using a Philips #0 screwdriver, unscrew the 4-mm-long screw that attaches the windscreen to the microphone.
Aggiungi Commento
Now that the screw is removed, remove the slim metal plate at the base of the windscreen by gently pulling on the plate. Then slide the windscreen off of the microphone.
  • Now that the screw is removed, remove the slim metal plate at the base of the windscreen by gently pulling on the plate.
  • Then slide the windscreen off of the microphone.
Aggiungi Commento
Conclusione
Andrew Rudnick
Membro da: 31/01/2015
266 Reputazione
2 Guide realizzate
Cal Poly, Team 17-36, Amido Winter 2015 Membro di Cal Poly, Team 17-36, Amido Winter 2015
CPSU-AMIDO-W15S17G36
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 41
Tutti i Tempi: 2,110
