Salta al contenuto principale
Triace A310 Chain Replacement
Cosa ti serve
  1. Triace A310 Chain Replacement, Tire: passo 1, immagine 1 di 1
    • Begin loosening the tire by turning the quick release handle.
  2. Triace A310 Chain Replacement: passo 2, immagine 1 di 2 Triace A310 Chain Replacement: passo 2, immagine 2 di 2
    • Gripping the rear derailleur, pull the arm back, away from the front of the bike.
    • Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
  3. Triace A310 Chain Replacement: passo 3, immagine 1 di 2 Triace A310 Chain Replacement: passo 3, immagine 2 di 2
    • There should be enough slack, in the chain, at this point to remove the tire from the bike.
    • Note: You may need to wiggle the tire and chain around in order to create enough slack.
    • Remove the tire from the bike.
  4. Triace A310 Chain Replacement, Chain: passo 4, immagine 1 di 3 Triace A310 Chain Replacement, Chain: passo 4, immagine 2 di 3 Triace A310 Chain Replacement, Chain: passo 4, immagine 3 di 3
    • Locate the master link along the chain.
    • Note: If the master link matches the one pictured in this step continue with the instructions, if not skip to the next step.
    • With pliers squeeze the two pins together so that the chain comes apart.
  5. Triace A310 Chain Replacement: passo 5, immagine 1 di 3 Triace A310 Chain Replacement: passo 5, immagine 2 di 3 Triace A310 Chain Replacement: passo 5, immagine 3 di 3
    • Note: This step is only for chains with a master link clip.
    • With a plier press the two pins together and remove the clip.
    • Once the clip is removed the chain should easily come apart.
  6. Triace A310 Chain Replacement: passo 6, immagine 1 di 1
    • Once the chain is separated, remove it from the bike by pulling one end.
  7. Triace A310 Chain Replacement: passo 7, immagine 1 di 3 Triace A310 Chain Replacement: passo 7, immagine 2 di 3 Triace A310 Chain Replacement: passo 7, immagine 3 di 3
    • With the new chain, place it on the current gear that your bike is in.
    • Note: If you don't know which gear your bike is in place the chain on one of the middle gears.
    • Thread one end of the chain through the derailleur from top to bottom so it is in the shape of a 'S'.
    • Next place the chain on the back gears, making sure that it is threaded through the guide.
  8. Triace A310 Chain Replacement: passo 8, immagine 1 di 3 Triace A310 Chain Replacement: passo 8, immagine 2 di 3 Triace A310 Chain Replacement: passo 8, immagine 3 di 3
    • To reassemble the chain bring both ends of the chain together so that the pins on each one lineup.
    • Grip the chain on both sides of the master link and pull.
  9. Triace A310 Chain Replacement: passo 9, immagine 1 di 3 Triace A310 Chain Replacement: passo 9, immagine 2 di 3 Triace A310 Chain Replacement: passo 9, immagine 3 di 3
    • If your chain does have a master link clip replace the link around the two pins.
    • Use a plier to slide the clip back into place.
Conclusione
Once your chain is back together, you are ready to once again, hit the trails.
Jacob Rickman
Membro da: 01/26/14
159 Reputazione
1 Guida realizzata
Cal Poly, Team 1-37, Maness Winter 2014 Membro di Cal Poly, Team 1-37, Maness Winter 2014
CPSU-MANESS-W14S1G37
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 704
