Salta al contenuto principale
Triace A310 Brake Cable Replacement
Cosa ti serve
  1. Triace A310 Brake Cable Replacement, Brake Cable: passo 1, immagine 1 di 2 Triace A310 Brake Cable Replacement, Brake Cable: passo 1, immagine 2 di 2
    • WARNING: Be sure to follow each step carefully. Failure to do so may result in serious injury or death.
    • Unscrew the screw holding the brake cable in place with a 5mm allen wrench and pull out the cable.
  2. Triace A310 Brake Cable Replacement: passo 2, immagine 1 di 3 Triace A310 Brake Cable Replacement: passo 2, immagine 2 di 3 Triace A310 Brake Cable Replacement: passo 2, immagine 3 di 3
    • Unscrew the slotted brake cable cap on the rear tire and pull out the cable. Remove the cap from the cable.
  3. Triace A310 Brake Cable Replacement: passo 3, immagine 1 di 2 Triace A310 Brake Cable Replacement: passo 3, immagine 2 di 2
    • Unscrew the cap next to the brake handle and remove it from the cable.
  4. Triace A310 Brake Cable Replacement: passo 4, immagine 1 di 3 Triace A310 Brake Cable Replacement: passo 4, immagine 2 di 3 Triace A310 Brake Cable Replacement: passo 4, immagine 3 di 3
    • Pull up and out on the cable to remove the barrel nipple (the small cylinder at the end of the cable).
  5. Triace A310 Brake Cable Replacement: passo 5, immagine 1 di 3 Triace A310 Brake Cable Replacement: passo 5, immagine 2 di 3 Triace A310 Brake Cable Replacement: passo 5, immagine 3 di 3
    • Unscrew the bracket located on the front tire with a 3mm allen wrench.
    • Rotate the bracket 90 degrees or until the opening is large enough for the cable. Remove the cable.
    • Note that if removing cable for rear brake, rather than unscrewing a bracket, you will unclip several "spring" clips. Keep track of clips.
    • Test your brakes in a low-speed environment to ensure that they work.
Conclusione
To place the new cable, follow these instructions in reverse order.
Ben Hartinger
Membro da: 01/27/14
340 Reputazione
3 Guide realizzate
Cal Poly, Team 1-37, Maness Winter 2014 Membro di Cal Poly, Team 1-37, Maness Winter 2014
CPSU-MANESS-W14S1G37
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 339
