Parti
Nessuna parte richiesta.
You will need the Allen Wrench 3/16" for this first step. Unscrew the silver cap with the Allen Wrench.
  • You will need the Allen Wrench 3/16" for this first step.
  • Unscrew the silver cap with the Allen Wrench.
Aggiungi Commento
You will need the Allen Wrench 7/32" for this step. Loosen all four of the screws using the Allen Wrench so that the handlebars can be wiggled off the frame. Loosen all four of the screws using the Allen Wrench so that the handlebars can be wiggled off the frame.
  • You will need the Allen Wrench 7/32" for this step.
  • Loosen all four of the screws using the Allen Wrench so that the handlebars can be wiggled off the frame.
Aggiungi Commento
When loose enough, slide the handlebars off the frame. When loose enough, slide the handlebars off the frame.
  • When loose enough, slide the handlebars off the frame.
Aggiungi Commento
Conclusione
Cal Poly, Team 1-1, Propen Fall 2012 Membro di Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 2,858
