Introduzione
The process for replacing the rim on the front and rear wheel are the same. This guide specifically shows removing the rim from the front wheel. To take off the rear wheel first reference the corresponding guide.
Cosa ti serve
Stand facing your bike and locate the brake calipers.
To lessen the tension on the brake wire, place one hand on each caliper and push them closer together.
To deflate the tire, remove the cap and attach the pump head to the valve. You should then hear air flowing out from the tire.
