Introduzione
Sometimes the hard drive is corrupt, or you want to install a new one. This guide will show you how to take out a hard drive and replace.
Lay laptop on it's face and remove the two #1 Phillips screws in the back of the black plastic panel with a raised center. The screws can not be removed from the panel, so loosen them until the panel can come off.
  • Lay laptop on it's face and remove the two #1 Phillips screws in the back of the black plastic panel with a raised center.
  • The screws can not be removed from the panel, so loosen them until the panel can come off.
  • Carefully lift the panel using the thumb slot on the side closest to you while the battery is pointed out.
Aggiungi Commento
After lifting the cover up carefully, slide it to the left to be removed.
  • After lifting the cover up carefully, slide it to the left to be removed.
Aggiungi Commento
Place two fingers gently on the hard drive. Slide it back to the left. Lift the drive by the two corner tabs making sure not to touch the metel
  • Place two fingers gently on the hard drive.
  • Slide it back to the left.
  • Lift the drive by the two corner tabs making sure not to touch the metel
  • Do not press down too hard on the top of the drive, or you will damage it. Only use enough pressure to be able to remove it from the SATA connection.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Brandon Kirklen
Membro da: 11/01/2013
269 Reputazione
8 Guide realizzate
Cal Poly, Team 7-8, Maness Winter 2013 Membro di Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 357
