Salta al contenuto principale
Toshiba Satellite U405D-S2902 Display Replacement
Cosa ti serve
  1. Toshiba Satellite U405D-S2902 Display Replacement, Display: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to remove the small rubber covers over the screws on the top and bottom of the laptop case.
  2. Toshiba Satellite U405D-S2902 Display Replacement: passo 2, immagine 1 di 2 Toshiba Satellite U405D-S2902 Display Replacement: passo 2, immagine 2 di 2
    • Use a #1 Phillips screwdriver to remove the 3mm screws located on both sides of the top of the laptop as well as the lower corners.
  3. Toshiba Satellite U405D-S2902 Display Replacement: passo 3, immagine 1 di 3 Toshiba Satellite U405D-S2902 Display Replacement: passo 3, immagine 2 di 3 Toshiba Satellite U405D-S2902 Display Replacement: passo 3, immagine 3 di 3
    • Use a plastic opening tool to separate the front plastic panel from the back side of the top of the laptop.
    • Carefully pull the top away from the back.
  4. Toshiba Satellite U405D-S2902 Display Replacement: passo 4, immagine 1 di 3 Toshiba Satellite U405D-S2902 Display Replacement: passo 4, immagine 2 di 3 Toshiba Satellite U405D-S2902 Display Replacement: passo 4, immagine 3 di 3
    • Turn the laptop around.
    • Remove the webcam/microphone data cable.
  5. Toshiba Satellite U405D-S2902 Display Replacement: passo 5, immagine 1 di 2 Toshiba Satellite U405D-S2902 Display Replacement: passo 5, immagine 2 di 2
    • Remove the lower lighting power supply.
    • Remove the signal light power supply and data cable.
  6. Toshiba Satellite U405D-S2902 Display Replacement: passo 6, immagine 1 di 2 Toshiba Satellite U405D-S2902 Display Replacement: passo 6, immagine 2 di 2
    • Locate and remove the four 2mm #1 Phillips screws around the sidewalls of the display.
    • After removing the last screw, the screen will be very loose, be sure to keep a hand on it to prevent it from damaging the keyboard.
  7. Toshiba Satellite U405D-S2902 Display Replacement: passo 7, immagine 1 di 2 Toshiba Satellite U405D-S2902 Display Replacement: passo 7, immagine 2 di 2
    • Carefully remove the screen from the side brackets.
    • Remove the LCD ribbon connector from the display.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 7-8, Maness Winter 2013 Membro di Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 694
