Salta al contenuto principale
Toshiba Satellite P55W-C5316 Battery Replacement
Cosa ti serve
  1. Toshiba Satellite P55W-C5316 Battery Replacement, Back Panel: passo 1, immagine 1 di 2 Toshiba Satellite P55W-C5316 Battery Replacement, Back Panel: passo 1, immagine 2 di 2
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 Battery Replacement: passo 2, immagine 1 di 3 Toshiba Satellite P55W-C5316 Battery Replacement: passo 2, immagine 2 di 3 Toshiba Satellite P55W-C5316 Battery Replacement: passo 2, immagine 3 di 3
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
  3. Toshiba Satellite P55W-C5316 Battery Replacement, Battery: passo 3, immagine 1 di 3 Toshiba Satellite P55W-C5316 Battery Replacement, Battery: passo 3, immagine 2 di 3 Toshiba Satellite P55W-C5316 Battery Replacement, Battery: passo 3, immagine 3 di 3
    • The battery is located in the bottom right corner of the laptop.
    • Remove the four .5mm Phillips head screws on the battery using the PH1 screwdriver.
  4. Toshiba Satellite P55W-C5316 Battery Replacement: passo 4, immagine 1 di 2 Toshiba Satellite P55W-C5316 Battery Replacement: passo 4, immagine 2 di 2
    • Do not tug on the cord or battery. Instead, pull evenly on the connector.
    • Lift the battery and gently pull out the bundled cable connector.
Conclusione
Altre 3 persone hanno completato questa guida.
Alec Bonnell
Membro da: 10/18/17
497 Reputazione
4 Guide realizzate
Un commento
Hello, please I've been searching and searching online to get motherboard for Toshiba Satellite P55W-C5316 but i don't seen to find any. Can anyone lead me to get one to buy.
Owusu Bright - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 29
Tutti i Tempi: 2,798
