Introduzione
This guide will take you through the steps of replacing your battery. You can use these to replace a malfunctioning battery for a new, working battery.
Flip the laptop over so the bottom is facing upward and the battery is on top. Slide the tab below the battery to the left.
  • Flip the laptop over so the bottom is facing upward and the battery is on top.
  • Slide the tab below the battery to the left.
Aggiungi Commento
Slide and hold the tab on the right side of the battery to the right. While holding the right tab, slide the battery upward and out its socket.
  • Slide and hold the tab on the right side of the battery to the right.
  • While holding the right tab, slide the battery upward and out its socket.
Aggiungi Commento
Conclusione
Rachel Cantor
Membro da: 03/02/2014
101 Reputazione
1 Guida realizzata
Cal Poly, Team 2-8, Amido Winter 2014 Membro di Cal Poly, Team 2-8, Amido Winter 2014
CPSU-AMIDO-W14S2G8
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 390
