Introduzione
This guide illustrates how to replace the RAM in your Toshiba Satellite.
Parti
Orient the laptop so that it is closed, faced down and has the battery facing away from you.
  • Orient the laptop so that it is closed, faced down and has the battery facing away from you.
  • Use the Phillips 00 screwdriver to remove the 7.50mm screw from the panel.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Carefully remove the cover to reveal the RAM compartment.
  • Carefully remove the cover to reveal the RAM compartment.
Aggiungi Commento
Rotate the laptop 90 degrees clockwise. Pull back the two silver clips that hold the RAM in place.
  • Rotate the laptop 90 degrees clockwise.
  • Pull back the two silver clips that hold the RAM in place.
  • Gently pull the RAM out of the slot and lift up to remove the RAM from the laptop.
Aggiungi Commento
Conclusione
Matthew Trinh
Membro da: 31/01/2013
63 Reputazione
4 Guide realizzate
Cal Poly, Team 7-11, Maness Winter 2013 Membro di Cal Poly, Team 7-11, Maness Winter 2013
CPSU-MANESS-W13S7G11
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,034
