Introduzione
This guide details the process of removing the keyboard from a Toshiba Satellite M55-S135 laptop. Installation of the keyboard can be accomplished by reversing the process.
Parti
Nessuna parte richiesta.
Start  with the laptop open and the keyboard facing you.
  • Start with the laptop open and the keyboard facing you.
  • Tilt the screen away from you to reduce the risk of damaging it as you remove the keyboard.
Aggiungi Commento
Locate the vertical seam between the speakers and the top row of keys on the keyboard. Insert the tip of a  flat head screw driver into the seam and slowly pry up the panel.
  • Locate the vertical seam between the speakers and the top row of keys on the keyboard.
  • Insert the tip of a flat head screw driver into the seam and slowly pry up the panel.
  • Be sure to gently pry the panel to avoid damaging it or the laptop.
Aggiungi Commento
Remove both 6.72mm screws from the upper left and right of the keyboard using the Phillips 00 screwdriver. Remove both 6.72mm screws from the upper left and right of the keyboard using the Phillips 00 screwdriver.
  • Remove both 6.72mm screws from the upper left and right of the keyboard using the Phillips 00 screwdriver.
Aggiungi Commento
Use the Flathead screwdriver to pry up the keyboard. Start with one side and then the other.
  • Use the Flathead screwdriver to pry up the keyboard. Start with one side and then the other.
  • Be sure to pry gently with the screwdriver to avoid damaging the keyboard and keys.
Aggiungi Commento
Gently lift the keyboard to reveal the keyboard cable located near the mouse pad.
  • Gently lift the keyboard to reveal the keyboard cable located near the mouse pad.
  • Disconnect the keyboard cable.
  • Be sure to disconnect the cable before removing the keyboard to avoid damaging it.
Aggiungi Commento
Conclusione
klismann Evora
Membro da: 12/03/2014
109 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 377
