Introduzione
Learn to replace your hard drive.
Parti
Nessuna parte richiesta.
Remove the hard drive screw labeled with a #1 Phillips head screwdriver  as indicated in the picture, then use a flat edge tool to pry the cover off. Use the plastic flap to pull the hard drive out of its slot. Use the plastic flap to pull the hard drive out of its slot.
  • Remove the hard drive screw labeled with a #1 Phillips head screwdriver as indicated in the picture, then use a flat edge tool to pry the cover off.
  • Use the plastic flap to pull the hard drive out of its slot.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 10-42, Garner Spring 2010 Membro di Cal Poly, Team 10-42, Garner Spring 2010
CPSU-GARNER-S10S10G42
5 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 9,833
