Introduzione
This guide describes how to remove the cooling unit of the Toshiba Satellite M45 laptop.
Parti
Nessuna parte richiesta.
Remove the cover from the cooling unit. Remove the cover from the cooling unit. Remove the cover from the cooling unit.
  • Remove the cover from the cooling unit.
Aggiungi Commento
Unscrew the copper heat-sink using a #1 screwdriver, and then lift it free. Do not get any thermal grease on any components. This part can now be replaced. Unscrew the copper heat-sink using a #1 screwdriver, and then lift it free. Do not get any thermal grease on any components. This part can now be replaced.
  • Unscrew the copper heat-sink using a #1 screwdriver, and then lift it free. Do not get any thermal grease on any components. This part can now be replaced.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Follow the tear-down guide until you have access to the fan unit on the motherboard.
  • Follow the tear-down guide until you have access to the fan unit on the motherboard.
Aggiungi Commento
Unscrew the fan unit from the motherboard using a #0 screwdriver. Once the fan is unscrewed and unplugged from the motherboard, it can be replaced. Unscrew the fan unit from the motherboard using a #0 screwdriver. Once the fan is unscrewed and unplugged from the motherboard, it can be replaced. Unscrew the fan unit from the motherboard using a #0 screwdriver. Once the fan is unscrewed and unplugged from the motherboard, it can be replaced.
  • Unscrew the fan unit from the motherboard using a #0 screwdriver. Once the fan is unscrewed and unplugged from the motherboard, it can be replaced.
Aggiungi Commento
Conclusione
Stephen
Membro da: 20/04/2010
352 Reputazione
3 Guide realizzate
Cal Poly, Team 10-42, Garner Spring 2010 Membro di Cal Poly, Team 10-42, Garner Spring 2010
CPSU-GARNER-S10S10G42
5 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 5,309
