Unscrew the three screws from the back panel with Phillips #0 screwdriver.
  • Unscrew the three screws from the back panel with Phillips #0 screwdriver.
  • Remove the back panel.
Aggiungi Commento
Locate the two clips holding the RAM chip in place. Apply pressure to each clip, pulling them away from the RAM. One end of the RAM will pop out.
  • Locate the two clips holding the RAM chip in place.
  • Apply pressure to each clip, pulling them away from the RAM.
  • One end of the RAM will pop out.
Aggiungi Commento
Gently pull RAM out as shown. Gently pull RAM out as shown.
  • Gently pull RAM out as shown.
Aggiungi Commento
To intall a new stick of RAM, carefully insert it into into the RAM slot.
  • To intall a new stick of RAM, carefully insert it into into the RAM slot.
  • Gently push down on the RAM chip until it snaps securely into place.
Aggiungi Commento
Conclusione
Michael Jensen
Membro da: 18/04/2011
417 Reputazione
6 Guide realizzate
Cal Poly, Team 4-3, Regan Spring 2011 Membro di Cal Poly, Team 4-3, Regan Spring 2011
CPSU-REGAN-S11S4G3
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,539
