Salta al contenuto principale
Toshiba Satellite M305D-S4829 Motherboard Replacement
Cosa ti serve
  1. Toshiba Satellite M305D-S4829 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Unlatch the battery by pushing outward on both latches.
  2. Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 2, immagine 1 di 1
    • Slide battery out.
  3. Toshiba Satellite M305D-S4829 Motherboard Replacement, Keyboard: passo 3, immagine 1 di 1
    • Remove the five "F2" screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 4, immagine 1 di 2 Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 4, immagine 2 di 2
    • Insert the plastic opening tool above the F1 key.
    • Apply upward pressure until the black plastic strip snaps off. The entire strip will easily come off from left to right.
  5. Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 5, immagine 1 di 2 Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 5, immagine 2 di 2
    • Find the screws above the F1 and INS keys.
    • Unscrew both screws with a Phillips #0 screwdriver.
  6. Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 6, immagine 1 di 2 Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 6, immagine 2 di 2
    • Slowly lift the top edge of the keyboard out with your fingers.
    • The ribbon cable located on the back of the keyboard will become accessible.
  7. Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 7, immagine 1 di 2 Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 7, immagine 2 di 2
    • Locate the black ribbon cable flap.
    • Detach flap with plastic opening tool. The ribbon cable will become free.
  8. Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 8, immagine 1 di 1
    • Your keyboard has now been successfully removed.
  9. Toshiba Satellite M305D-S4829 Motherboard Replacement, CD/DVD Drive: passo 9, immagine 1 di 1
    • Remove the back panel by removing the three labeled screws with a Phillips #0 screwdriver.
  10. Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 10, immagine 1 di 2 Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 10, immagine 2 di 2
    • Locate and remove the circled screw with a Phillips #0 screwdriver.
  11. Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 11, immagine 1 di 1
    • Use the plastic opening tool to pry the CD/DVD drive out of the frame.
  12. Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 12, immagine 1 di 1
    • Gently remove the CD/DVD drive from the laptop body.
  13. Toshiba Satellite M305D-S4829 Motherboard Replacement, also remove these two screws: passo 13, immagine 1 di 2 Toshiba Satellite M305D-S4829 Motherboard Replacement, also remove these two screws: passo 13, immagine 2 di 2
    • Remove the circled screws with Phillips #0 screwdriver.
  14. Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 14, immagine 1 di 1
    • Remove these screws from the underside of the laptop with Phillips #0 screwdriver.
  15. Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 15, immagine 1 di 1
    • Disconnect the three circled antennas by lightly pulling upward with your fingers. They should detach easily.
    • Note: Yours may only have two (2) antennas. Pay attention to the Orientation of the Aluminum bracket with the pads for reinstallation.
  16. Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 16, immagine 1 di 1
    • Remove the circled screw with a Phillips #0 screwdriver.
  17. Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 17, immagine 1 di 1
    • Detach the 3 marked cables by pulling them out with you fingers as shown.
    • This may require some force. They do not come out easily.
  18. Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 18, immagine 1 di 1
    • Detach the four blue ribbon cables carefully with tweezers. Some of the ribbons may require a flap to be raised because it secures the ribbon in.
  19. Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 19, immagine 1 di 1
    • Remove the top plastic cover by lifting upward from the bottom left-hand corner as shown. The cover will come off easily.
  20. Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 20, immagine 1 di 1
    • Remove the circled motherboard screws with a Phillips #0 Scewdriver.
    • Disconnect this ribbon cable.
  21. Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 21, immagine 1 di 1
    • Remove these screws with a Phillips #0 screwdriver.
  22. Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 22, immagine 1 di 1
    • Detach the display cable by gently pulling it out with your fingers.
  23. Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 23, immagine 1 di 2 Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 23, immagine 2 di 2
    • Remove the motherboard from the left side by gently lifting the left side upward.
    • The boxed volume control may snag on the laptop frame when pulling the motherboard out.
  24. Toshiba Satellite M305D-S4829 Motherboard Replacement: passo 24, immagine 1 di 1
    • The motherboard has now been removed from laptop.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 4-3, Regan Spring 2011 Membro di Cal Poly, Team 4-3, Regan Spring 2011
CPSU-REGAN-S11S4G3
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 11
Tutti i Tempi: 11,825
