Parti
Nessuna parte richiesta.
Unlatch the battery by pushing outward on both latches.
  • Unlatch the battery by pushing outward on both latches.
Aggiungi Commento
Slide battery out.
  • Slide battery out.
Aggiungi Commento
Remove the back panel by removing the three labeled screws with a Phillips #0 screwdriver.
  • Remove the back panel by removing the three labeled screws with a Phillips #0 screwdriver.
Aggiungi Commento
Locate and remove the circled screw with a Phillips #0 screwdriver. Locate and remove the circled screw with a Phillips #0 screwdriver.
  • Locate and remove the circled screw with a Phillips #0 screwdriver.
Aggiungi Commento
Use the plastic opening tool to pry the CD/DVD drive out of the frame.
  • Use the plastic opening tool to pry the CD/DVD drive out of the frame.
Aggiungi Commento
Gently remove the CD/DVD drive from the laptop body.
  • Gently remove the CD/DVD drive from the laptop body.
Aggiungi Commento
Conclusione
Michael Jensen
Membro da: 18/04/2011
417 Reputazione
6 Guide realizzate
Cal Poly, Team 4-3, Regan Spring 2011 Membro di Cal Poly, Team 4-3, Regan Spring 2011
CPSU-REGAN-S11S4G3
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,757
