Introduzione
Replacing the battery is a simple fix that even a beginner can accomplish successfully.
Locate the battery locks on the bottom of the laptop. Slide the right lock outwards, until it locks into place. Slide and hold the left lock outwards and hold it in place.
  • Locate the battery locks on the bottom of the laptop.
  • Slide the right lock outwards, until it locks into place.
  • Slide and hold the left lock outwards and hold it in place.
Aggiungi Commento
While holding the lock in place, slide the battery out towards you.
  • While holding the lock in place, slide the battery out towards you.
Aggiungi Commento
Conclusione
To reinsert the battery, follow the steps in reverse order, remembering to slide the right lock back into place.
Altre 2 persone hanno completato questa guida.
Jerry Wakai
Membro da: 31/01/2013
284 Reputazione
4 Guide realizzate
Cal Poly, Team 7-7, Maness Winter 2013 Membro di Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,212
