Introduzione
In order to replace the speakers on your device the keyboard and motherboard cover need to be removed first.
Parti
Nessuna parte richiesta.
Locate the two sliding battery locks on the underside of the laptop.
  • Locate the two sliding battery locks on the underside of the laptop.
Aggiungi Commento
Locate the right battery lock and slide it to the right. Locate the right battery lock and slide it to the right.
  • Locate the right battery lock and slide it to the right.
Aggiungi Commento
While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery. While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
Aggiungi Commento
Remove the battery from the laptop.
  • Remove the battery from the laptop.
Aggiungi Commento
Locate the plastic strip at the top of the keyboard. Use a pry tool to remove the plastic strip.
  • Locate the plastic strip at the top of the keyboard.
  • Use a pry tool to remove the plastic strip.
  • Using your hands pull out the rest of the plastic strip.
Aggiungi Commento
Use a phillips head #0 screwdriver to remove the two  3.75mm screws holding the keyboard in place.
  • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
Aggiungi Commento
Lift up the top of the keyboard to remove it. Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard. Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
  • Lift up the top of the keyboard to remove it.
  • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
  • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
  • Unplug the ribbon cable from the laptop.
Aggiungi Commento
Remove the keyboard completely from the laptop.
  • Remove the keyboard completely from the laptop.
Aggiungi Commento
Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm. Remove all  5.25mm screws from the top of the laptop.
  • Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
  • Remove all 5.25mm screws from the top of the laptop.
Aggiungi Commento
Unplug the wires highlighted with red squares. Using a pry tool and yours hands to remove the motherboard cover. Using a pry tool and yours hands to remove the motherboard cover.
  • Unplug the wires highlighted with red squares.
  • Using a pry tool and yours hands to remove the motherboard cover.
Aggiungi Commento
Use a phillips head #00 screwdriver to remove the two 5.25mm screws. Use a phillips head #00 screwdriver to remove the two 5.25mm screws.
  • Use a phillips head #00 screwdriver to remove the two 5.25mm screws.
Aggiungi Commento
Turn the keyboard housing over and disconnect the speaker power wire from the keyboard housing. Remove both speakers.
  • Turn the keyboard housing over and disconnect the speaker power wire from the keyboard housing.
  • Remove both speakers.
Aggiungi Commento
Conclusione
William
Membro da: 26/03/2014
827 Reputazione
7 Guide realizzate
Clemson, Team 1-2, Benson Spring 2014 Membro di Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
3 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 183
