Locate the two sliding battery locks on the underside of the laptop.
  • Locate the two sliding battery locks on the underside of the laptop.
Aggiungi Commento
Locate the right battery lock and slide it to the right. Locate the right battery lock and slide it to the right.
  • Locate the right battery lock and slide it to the right.
Aggiungi Commento
While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery. While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
Aggiungi Commento
Remove the battery from the laptop.
  • Remove the battery from the laptop.
Aggiungi Commento
Locate the RAM cover on the underside of the laptop.
  • Locate the RAM cover on the underside of the laptop.
Aggiungi Commento
Use a phillips head #0 screwdriver to remove the screw located on the RAM cover.
  • Use a phillips head #0 screwdriver to remove the screw located on the RAM cover.
Aggiungi Commento
Using your fingers, carefully remove the cover. Using your fingers, carefully remove the cover.
  • Using your fingers, carefully remove the cover.
Aggiungi Commento
Conclusione
William
Membro da: 26/03/2014
827 Reputazione
7 Guide realizzate
Clemson, Team 1-2, Benson Spring 2014 Membro di Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
3 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 167
