Introduzione
Use this guide to replace a faulty power jack in your Toshiba Satellite L305-S5946, which is usually indicated by the computer failing to charge. You must remove the base housing in order to reach the power jack.
Turn the laptop upside-down.
  • Turn the laptop upside-down.
  • Position the laptop so that the display hinges are facing away from you.
Aggiungi Commento
Slide the left battery bay latch to the left.
  • Slide the left battery bay latch to the left.
Aggiungi Commento
Slide the right battery bay latch to the right and hold. While holding onto the latch, use a plastic opening tool to lift and remove the battery bay cover. Remove the battery.
  • Slide the right battery bay latch to the right and hold.
  • While holding onto the latch, use a plastic opening tool to lift and remove the battery bay cover.
  • Remove the battery.
Aggiungi Commento
Use a Phillips #1 screwdriver to loosen the two screws on the bottom left-hand side of the hard drive cover.
  • Use a Phillips #1 screwdriver to loosen the two screws on the bottom left-hand side of the hard drive cover.
  • Turn each screw until you hear a click.
    • These are captive panel screws and remain with the cover.
Aggiungi Commento
Lift the hard drive cover using a non-marring plastic opening tool. This will expose the hard drive.
  • Lift the hard drive cover using a non-marring plastic opening tool.
    • This will expose the hard drive.
Aggiungi Commento
Slide the hard drive to the left using your fingers. Insert a plastic opening tool under the right side of the hard drive. Carefully lift and remove the hard drive.
  • Slide the hard drive to the left using your fingers.
  • Insert a plastic opening tool under the right side of the hard drive.
  • Carefully lift and remove the hard drive.
Aggiungi Commento
Use a Phillips #1 screwdriver to turn the screw on the RAM cover.
  • Use a Phillips #1 screwdriver to turn the screw on the RAM cover.
  • Turn the screw until you hear a click.
    • This is a captive panel screw and remains with the cover.
Aggiungi Commento
Insert the plastic opening tool into the indent and lift to remove the RAM cover. This is a captive panel screw and remains with the cover.
  • Insert the plastic opening tool into the indent and lift to remove the RAM cover.
Aggiungi Commento
Use your fingernails to push the white and silver retaining clips away from each side of the RAM card. The RAM card should pop up at an angle.
  • Use your fingernails to push the white and silver retaining clips away from each side of the RAM card.
    • The RAM card should pop up at an angle.
Aggiungi Commento
Use your fingers to gently pull the RAM card away from the computer. Repeat step 9 to remove the other RAM card that may be installed.
  • Use your fingers to gently pull the RAM card away from the computer.
  • Repeat step 9 to remove the other RAM card that may be installed.
Aggiungi Commento
Turn the laptop right-side up.
  • Turn the laptop right-side up.
  • Lift open the laptop so that the screen faces you.
Aggiungi Commento
Remove the strip of plastic at the right furthermost edge of the keyboard using a plastic opening tool. Insert the plastic opening tool at either end of the strip. Lift upwards and proceed to the other end while repeating this lifting process every one to two inches. Insert the plastic opening tool at either end of the strip. Lift upwards and proceed to the other end while repeating this lifting process every one to two inches.
  • Remove the strip of plastic at the right furthermost edge of the keyboard using a plastic opening tool.
  • Insert the plastic opening tool at either end of the strip. Lift upwards and proceed to the other end while repeating this lifting process every one to two inches.
Aggiungi Commento
Use a Philips #00 screwdriver to loosen and remove the two 3-mm screws at the top edge of the keyboard.
  • Use a Philips #00 screwdriver to loosen and remove the two 3-mm screws at the top edge of the keyboard.
    • These are not captive panel screws and, once loosened, will be free to move about the assembly.
    • Be careful not to allow either fastener into the CPU fan and duct (not shown).
Aggiungi Commento
Use a plastic opening tool to pry the top of the keyboard loose from its casing. Use a plastic opening tool to pry the top of the keyboard loose from its casing.
  • Use a plastic opening tool to pry the top of the keyboard loose from its casing.
Aggiungi Commento
Gently grasp the top of the keyboard. Pull it up and toward the screen.
  • Gently grasp the top of the keyboard. Pull it up and toward the screen.
  • Avoid pulling hard and damaging the black ribbon cable under the keyboard.
Aggiungi Commento
Gently push the two tabs locking the black ribbon cable. Slide the keyboard toward the screen to remove the black ribbon cable from the motherboard. You may now safely separate the keyboard from the laptop.
  • Gently push the two tabs locking the black ribbon cable.
  • Slide the keyboard toward the screen to remove the black ribbon cable from the motherboard.
  • You may now safely separate the keyboard from the laptop.
Aggiungi Commento
Turn the laptop upside-down with its hinges facing away from you.
  • Turn the laptop upside-down with its hinges facing away from you.
Aggiungi Commento
Use a Phillips #1 screwdriver to remove the twelve 6-mm screws that borders the bottom of the laptop.
  • Use a Phillips #1 screwdriver to remove the twelve 6-mm screws that borders the bottom of the laptop.
    • Start with the three screws on the top right corner and work clockwise. This will minimize the chances missing some of the screws.
  • Use a Phillips #1 screwdriver to remove a 6-mm screw that is located in the lower middle, as shown.
  • Use a Phillips #1 screwdriver to remove the three 3-mm screws located in the battery bay.
  • Use a Phillips #1 screwdriver to remove the one 4-mm screw located near the RAM.
Aggiungi Commento
  • Flip open the laptop so that the screen faces you.
Aggiungi Commento
Use a Phillips #1 screwdriver to remove the five 6-mm screws in the keyboard slot.
  • Use a Phillips #1 screwdriver to remove the five 6-mm screws in the keyboard slot.
    • Be careful not to allow loosened fasteners into the CPU fan and duct (located in the upper left).
Aggiungi Commento
Gently pull on the two black tabs locking the white ribbon cable in place. Pull the white ribbon cable towards you to remove it. Use tweezers to remove the connector that has the blue, red, black, and white wires.
  • Gently pull on the two black tabs locking the white ribbon cable in place.
  • Pull the white ribbon cable towards you to remove it.
  • Use tweezers to remove the connector that has the blue, red, black, and white wires.
Aggiungi Commento
Use a plastic opening tool to pry the laptop's upper casing off of its lower casing. Move the opening tool around the sides of the case to help separate them. Use a plastic opening tool to pry the laptop's upper casing off of its lower casing. Move the opening tool around the sides of the case to help separate them. Use a plastic opening tool to pry the laptop's upper casing off of its lower casing. Move the opening tool around the sides of the case to help separate them.
  • Use a plastic opening tool to pry the laptop's upper casing off of its lower casing. Move the opening tool around the sides of the case to help separate them.
Aggiungi Commento
Flip over your laptop so that it is right-side up.
  • Flip over your laptop so that it is right-side up.
  • Open your laptop so that the screen faces you.
Aggiungi Commento
Using your fingers, gently slide the DVD drive out through the opening on the right side. Using your fingers, gently slide the DVD drive out through the opening on the right side.
  • Using your fingers, gently slide the DVD drive out through the opening on the right side.
Aggiungi Commento
Using your fingers, gently slide the heading with two black wires and two red wires out of its receptacle. Gently slide the power jack up. Using your fingers, gently slide the heading with two black wires and two red wires out of its receptacle. Gently slide the power jack up. Using your fingers, gently slide the heading with two black wires and two red wires out of its receptacle. Gently slide the power jack up.
  • Using your fingers, gently slide the heading with two black wires and two red wires out of its receptacle. Gently slide the power jack up.
Aggiungi Commento
Conclusione
Altre 8 persone hanno completato questa guida.
Cal Poly, Team 3-49, Amido Spring 2013 Membro di Cal Poly, Team 3-49, Amido Spring 2013
CPSU-AMIDO-S13S3G49
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 16
Tutti i Tempi: 6,672
