Introduzione
Use this guide to replace the battery in your Toshiba. If your battery is damaged or won't hold a charge, it should be replaced.
Parti
Nessuna parte richiesta.
Turn the laptop upside-down.
  • Turn the laptop upside-down.
  • Position the laptop so that the display hinges are facing away from you.
Aggiungi Commento
Slide the left battery bay latch to the left.
  • Slide the left battery bay latch to the left.
Aggiungi Commento
Slide the right battery bay latch to the right and hold. While holding onto the latch, use a plastic opening tool to lift and remove the battery bay cover. Remove the battery.
  • Slide the right battery bay latch to the right and hold.
  • While holding onto the latch, use a plastic opening tool to lift and remove the battery bay cover.
  • Remove the battery.
Aggiungi Commento
Conclusione
Cal Poly, Team 3-49, Amido Spring 2013 Membro di Cal Poly, Team 3-49, Amido Spring 2013
CPSU-AMIDO-S13S3G49
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 580
