Introduzione
If your speakers lose their sound quality, it is possible to replace them.
Parti
Nessuna parte richiesta.
Close the laptop lid and flip the laptop over.
  • Close the laptop lid and flip the laptop over.
  • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
Aggiungi Commento
Push the release button to the right. Hold the release button to the right and lift the battery out of its housing. Hold the release button to the right and lift the battery out of its housing.
  • Push the release button to the right.
  • Hold the release button to the right and lift the battery out of its housing.
Aggiungi Commento
Open the laptop so the keyboard is facing you and the locate the thin plastic cover located directly above the keyboard. Using your fingers, remove this long piece of plastic gently. Do not apply too much force when removing the cover piece as it can break.
  • Open the laptop so the keyboard is facing you and the locate the thin plastic cover located directly above the keyboard.
  • Using your fingers, remove this long piece of plastic gently.
  • Do not apply too much force when removing the cover piece as it can break.
Aggiungi Commento
Remove the two 4.8 mm type-0 Phillips head screws located underneath the plastic cover piece.
  • Remove the two 4.8 mm type-0 Phillips head screws located underneath the plastic cover piece.
Aggiungi Commento
Starting at the top, gently raise the keyboard enough to remove it from the socket. DO NOT pull out the keyboard after its out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
  • Starting at the top, gently raise the keyboard enough to remove it from the socket.
  • DO NOT pull out the keyboard after its out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
Aggiungi Commento
Locate the data cable that is connected to the motherboard. Pull the white ZIF connector towards the screen to remove it.
  • Locate the data cable that is connected to the motherboard.
  • Pull the white ZIF connector towards the screen to remove it.
  • Pull the black ribbon cable away from the screen.
Aggiungi Commento
With the black ribbon cable now disconnected, remove the keyboard from  its housing.
  • With the black ribbon cable now disconnected, remove the keyboard from its housing.
Aggiungi Commento
Close the laptop and flip it over.
  • Close the laptop and flip it over.
  • Remove all the 6.6 mm type-00 Phillips head screws along the perimeter and in the center of the laptop.
Aggiungi Commento
Remove the three 3.7 mm type-00 Phillips head screws located in the battery compartment.
  • Remove the three 3.7 mm type-00 Phillips head screws located in the battery compartment.
Aggiungi Commento
Flip the laptop over and open the screen as far back as it can go. Flip the laptop over and open the screen as far back as it can go.
  • Flip the laptop over and open the screen as far back as it can go.
Aggiungi Commento
Using your fingers, slide the black ZIF connector out. Once the ZIF connector has been moved, the white ribbon cable can be removed.
  • Using your fingers, slide the black ZIF connector out.
  • Once the ZIF connector has been moved, the white ribbon cable can be removed.
Aggiungi Commento
Using your fingers, remove the white plastic connector located to the right of the ribbon connector. Using your fingers, remove the white plastic connector located to the right of the ribbon connector.
  • Using your fingers, remove the white plastic connector located to the right of the ribbon connector.
Aggiungi Commento
Use the blue plastic opening tool to begin removing the cover. After creating enough space, you can use your hands to completely open the cover. Make sure all the screws have been removed before attempting to open the cover.
  • Use the blue plastic opening tool to begin removing the cover.
  • After creating enough space, you can use your hands to completely open the cover.
  • Make sure all the screws have been removed before attempting to open the cover.
Aggiungi Commento
Put the laptop aside and locate the speakers attached to the cover. Remove the two 3.6 mm type-00 Phillips head screws from each speaker.
  • Put the laptop aside and locate the speakers attached to the cover.
  • Remove the two 3.6 mm type-00 Phillips head screws from each speaker.
Aggiungi Commento
Conclusione
Juan
Membro da: 11/01/2013
109 Reputazione
3 Guide realizzate
Cal Poly, Team 20-5, Maness Winter 2013 Membro di Cal Poly, Team 20-5, Maness Winter 2013
CPSU-MANESS-W13S20G5
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,033
