Introduzione
The battery supplies the device with power without having to keep the device plugged into a charger. If your device will not turn on, try plugging it into the charger. If that doesn't work, use this guide to replace the battery.
Slide both of the latches to the outside to release the battery. Slide both of the latches to the outside to release the battery.
  • Slide both of the latches to the outside to release the battery.
Aggiungi Commento
Pull the battery out by lifting the battery cover away from the laptop. Pull the battery out by lifting the battery cover away from the laptop.
  • Pull the battery out by lifting the battery cover away from the laptop.
Aggiungi Commento
Conclusione
Andrew Godsil
Membro da: 11/01/2013
29 Reputazione
1 Guida realizzata
Cal Poly, Team 17-21, Forte Winter 2013 Membro di Cal Poly, Team 17-21, Forte Winter 2013
CPSU-FORTE-W13S17G21
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 554
