Salta al contenuto principale
Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement
Cosa ti serve
Panoramica Video
  1. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement, WiFi / Bluetooth mini PCI express card: passo 1, immagine 1 di 3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement, WiFi / Bluetooth mini PCI express card: passo 1, immagine 2 di 3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement, WiFi / Bluetooth mini PCI express card: passo 1, immagine 3 di 3
    • Switch-off the laptop and remove the battery.
    • Use cutter and plastic tool to remove the Keyboard, held by 7x locking clips.
  2. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: passo 2, immagine 1 di 3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: passo 2, immagine 2 di 3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: passo 2, immagine 3 di 3
    • Remove 7x screws from the upper case.
    • Disassemble the HDD, RAM Memory cover and remove the HDD (just for safety).
    • Then remove 12x screws so you can start with disassembling the bottom case.
  3. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: passo 3, immagine 1 di 3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: passo 3, immagine 2 di 3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: passo 3, immagine 3 di 3
    • Use a plastic tool for separating the bottom case from the laptop.
  4. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: passo 4, immagine 1 di 2 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: passo 4, immagine 2 di 2
    • Here is the WiFi, Bluetooth half mini PCIe card.
    • Disconnect 2x antenna cables (luetooth and WiFi).
    • The mini PCI card is held by one small screw.
    • Did you do it successfully?
Conclusione
Altre 5 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.368 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.468 Guide realizzate
3 Commenti
This card is mini pcie (express) not mini pci. A small quibble but it did cause me to waste time looking at it.
mknoy - Replica
You're right, my mistake.
ZFix -
This is a great explanation (exactly what I would have done), but I’m unable to find info on which pcie WiFi cards are compatible with C850. I want to install a 2400Mbps card, but uncertain if it will be compatible. Do you have any info/advice on this?
Matthew Rummins - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 59
Tutti i Tempi: 8,091
