Introduzione
Is your computer running slow? Just need some more space? In this installation guide we are going to take you through the steps to install Random Access Memory (RAM) in your Toshiba Satellite C655D-S5084.
Turn the laptop over and place upside down on a flat surface. Remove the 5.5 mm "F5" screw with the Phillips #1 screwdriver and lift off plastic cover.
  • Turn the laptop over and place upside down on a flat surface.
  • Remove the 5.5 mm "F5" screw with the Phillips #1 screwdriver and lift off plastic cover.
Aggiungi Commento
Take two fingers and gently pull the two metal tabs away from the RAM module as shown.
  • Take two fingers and gently pull the two metal tabs away from the RAM module as shown.
    • There are two tabs for each of the two RAM modules.
    • The RAM module should be slightly dislodged from the base after the two tabs are pulled.
Aggiungi Commento
Grip the edge of the card and slide the RAM module out by pulling horizontally.
  • Grip the edge of the card and slide the RAM module out by pulling horizontally.
  • Once the first RAM module has been removed, repeat steps 2 and 3 to remove the second RAM module.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Shelby Kunz
Membro da: 19/04/2013
45 Reputazione
5 Guide realizzate
Cal Poly, Team 2-20, Maness Spring 2013 Membro di Cal Poly, Team 2-20, Maness Spring 2013
CPSU-MANESS-S13S2G20
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,394
