Introduzione
Use this guide to remove, replace, or install the battery of your Toshiba laptop.
Strumenti
Nessun attrezzo richiesto.
Power off the laptop.
  • Power off the laptop.
  • Disconnect the power cable from the laptop. If you do not, electric shock may result.
Aggiungi Commento
Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
  • Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
  • Unlock the battery by sliding the tab shown to the right
    • This tab will latch into place.
Aggiungi Commento
Slide the tab shown to the left and remain holding it. This tab does not lock into place like in the first step.
  • Slide the tab shown to the left and remain holding it.
    • This tab does not lock into place like in the first step.
  • Place your thumb on the grips of the battery as shown.
    • While holding onto the grips, pull the battery towards you and away from the laptop.
Aggiungi Commento
Conclusione
Travis
Membro da: 13/04/2013
13 Reputazione
5 Guide realizzate
Cal Poly, Team 10-38, Amido Spring 2013 Membro di Cal Poly, Team 10-38, Amido Spring 2013
CPSU-AMIDO-S13S10G38
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 365
