Introduzione
This a very simple guide to replacing or remove the CD-ROM drive from your Toshiba Satellite A75-S226.
Parti
Nessuna parte richiesta.
Remove the two 5.62 mm screws from the optical drive cover. Remove the two 5.62 mm screws from the optical drive cover.
  • Remove the two 5.62 mm screws from the optical drive cover.
Aggiungi Commento
Remove the optical drive cover. A plastic opening tool or a fingernail may be helpful in lifting it from its groove.
  • Remove the optical drive cover.
    • A plastic opening tool or a fingernail may be helpful in lifting it from its groove.
Aggiungi Commento
Using the inset divot, push the optical drive out of the laptop to remove.
  • Using the inset divot, push the optical drive out of the laptop to remove.
Aggiungi Commento
Conclusione
Garrett Gudgel
Membro da: 05/10/2010
714 Reputazione
13 Guide realizzate
Cal Poly, Team 4-43, Amido Fall 2010 Membro di Cal Poly, Team 4-43, Amido Fall 2010
CPSU-AMIDO-F10S4G43
5 Membri
13 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 4,646
