Introduzione
This a very simple guide to replace or remove the CD-ROM drive from your Toshiba Satellite A75-S226. Remember when repairing the internal components of an electronic device, a dry and clean environment is ideal.
Parti
Nessuna parte richiesta.
Remove the two 5.62 mm screws from the optical drive cover. Remove the two 5.62 mm screws from the optical drive cover.
  • Remove the two 5.62 mm screws from the optical drive cover.
Aggiungi Commento
Remove the optical drive cover. A plastic opening tool or a fingernail may be helpful in lifting it from its groove.
  • Remove the optical drive cover.
    • A plastic opening tool or a fingernail may be helpful in lifting it from its groove.
Aggiungi Commento
Using the inset divot, push the optical drive out of the laptop to remove.
  • Using the inset divot, push the optical drive out of the laptop to remove.
Aggiungi Commento
Remove the 8.6 mm screw. Remove the 8.6 mm screw. Remove the 8.6 mm screw.
  • Remove the 8.6 mm screw.
Aggiungi Commento
Push the bottom left corner of the CD Drive until the drive protrudes from the case. When a good amount of the CD Drive is showing on the right side, gently pull it out completely. When a good amount of the CD Drive is showing on the right side, gently pull it out completely.
  • Push the bottom left corner of the CD Drive until the drive protrudes from the case.
  • When a good amount of the CD Drive is showing on the right side, gently pull it out completely.
Aggiungi Commento
Conclusione
Garrett Gudgel
Membro da: 05/10/2010
714 Reputazione
13 Guide realizzate
Cal Poly, Team 4-43, Amido Fall 2010 Membro di Cal Poly, Team 4-43, Amido Fall 2010
CPSU-AMIDO-F10S4G43
5 Membri
13 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,132
