Salta al contenuto principale
Toshiba Satellite A665-S5170 Battery Replacement
Cosa ti serve
  1. Toshiba Satellite A665-S5170 Battery Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite A665-S5170 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the computer upside-down so that the bottom of the laptop is facing up.
    • Position the computer so that you are able to read the words on the labels on the bottom of the laptop from left to right.
    • Using the tip of your finger, slide the right clasp of the battery panel horizontally to the right until it locks into place.
  2. Toshiba Satellite A665-S5170 Battery Replacement: passo 2, immagine 1 di 1
    • Slide the left clasp of the battery panel horizontally to the left, and hold it in place.
    • You will have to continue holding the left clasp of the battery panel in place for future steps in order to remove the battery.
  3. Toshiba Satellite A665-S5170 Battery Replacement: passo 3, immagine 1 di 3 Toshiba Satellite A665-S5170 Battery Replacement: passo 3, immagine 2 di 3 Toshiba Satellite A665-S5170 Battery Replacement: passo 3, immagine 3 di 3
    • While continuing to hold the left clasp of the battery panel in place, slide out the old battery by pulling it towards you.
Conclusione
Altre 2 persone hanno completato questa guida.
Baylor, Team 4-5, Williams Fall 2016 Membro di Baylor, Team 4-5, Williams Fall 2016
BU-WILLIAMS-F16S4G5
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,129
