Salta al contenuto principale
Toshiba Satellite A660-ST3NX2X RAM Replacement
Cosa ti serve
  1. Toshiba Satellite A660-ST3NX2X RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Unplug all cables and other devices from the computer before starting this replacement.
    • Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
  2. Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 2, immagine 1 di 2 Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 2, immagine 2 di 2
    • Locate the two sliding tabs on either side of the battery.
    • Using both hands, place one finger on each tab and slide them to the sides and away from each other.
  3. Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 3, immagine 1 di 3 Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 3, immagine 2 di 3 Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 3, immagine 3 di 3
    • Pull the battery out, keeping the tabs pushed to the side.
    • The right tab on this laptop stayed pushed to the right without needing to be held in place.
  4. Toshiba Satellite A660-ST3NX2X RAM Replacement, RAM Memory: passo 4, immagine 1 di 2 Toshiba Satellite A660-ST3NX2X RAM Replacement, RAM Memory: passo 4, immagine 2 di 2
    • Use a J00 bit to unscrew the single 4mm screw that leads to the RAM Memory compartment.
  5. Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 5, immagine 1 di 1
    • Open the hatch that holds the RAM cards.
  6. Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 6, immagine 1 di 2 Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 6, immagine 2 di 2
    • Pull apart the two metal tabs that are holding the RAM cards in place.
    • You will feel the card pop up from its held position, indicating it can safely be pulled out.
  7. Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 7, immagine 1 di 2 Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 7, immagine 2 di 2
    • Pull out the top RAM card.
  8. Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 8, immagine 1 di 2 Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 8, immagine 2 di 2
    • Use tabs on the sides of the bottom RAM card to release the RAM card.
    • Remove the bottom RAM card, just as the top RAM card was removed.
Conclusione
Cassie Pickett
Membro da: 03/20/17
201 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 11
Tutti i Tempi: 368
