Salta al contenuto principale
Toshiba Satellite A660-ST3NX2X Battery Replacement
Cosa ti serve
  1. Toshiba Satellite A660-ST3NX2X Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Unplug all cables and other devices from the computer before starting this replacement.
    • Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
  2. Toshiba Satellite A660-ST3NX2X Battery Replacement: passo 2, immagine 1 di 2 Toshiba Satellite A660-ST3NX2X Battery Replacement: passo 2, immagine 2 di 2
    • Locate the two sliding tabs on either side of the battery.
    • Using both hands, place one finger on each tab and slide them to the sides and away from each other.
  3. Toshiba Satellite A660-ST3NX2X Battery Replacement: passo 3, immagine 1 di 3 Toshiba Satellite A660-ST3NX2X Battery Replacement: passo 3, immagine 2 di 3 Toshiba Satellite A660-ST3NX2X Battery Replacement: passo 3, immagine 3 di 3
    • Pull the battery out, keeping the tabs pushed to the side.
    • The right tab on this laptop stayed pushed to the right without needing to be held in place.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 511
