Introduzione
The optical drive contains both precise lasers and lenses and a powerful motor to read and write disk drives. And we know that precision and fast spinning doesn't go well with each other. But don't worry! If your optical drive is giving you trouble, you can easily replace it with a new one.
Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you. Find the battery compartment. Slide the left slider which is just beneath the battery compartment into its leftmost position.
  • Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
  • Find the battery compartment.
  • Slide the left slider which is just beneath the battery compartment into its leftmost position.
Aggiungi Commento
Slide and hold the right slider into its rightmost position. Lift the battery out of the compartment. Do not touch the gold nodes inside the compartment. Do not touch the gold nodes inside the compartment.
  • Slide and hold the right slider into its rightmost position. Lift the battery out of the compartment.
  • Do not touch the gold nodes inside the compartment.
Aggiungi Commento
Turn computer over so that the battery compartment is facing up and is at the top. Locate and unscrew one captive Phillips #1 screw located at the center. A captive screw cannot be completely removed from the device's component.
  • Turn computer over so that the battery compartment is facing up and is at the top.
  • Locate and unscrew one captive Phillips #1 screw located at the center.
  • A captive screw cannot be completely removed from the device's component.
Aggiungi Commento
Use a plastic opening tool to open the motherboard access cover. Do not touch the motherboard. Do not touch the motherboard.
  • Use a plastic opening tool to open the motherboard access cover.
  • Do not touch the motherboard.
Aggiungi Commento
Remove one 1.5mm Phillips #1 screw located near the top left edge of the opening. Remove one 1.5mm Phillips #1 screw located near the top left edge of the opening. Remove one 1.5mm Phillips #1 screw located near the top left edge of the opening.
  • Remove one 1.5mm Phillips #1 screw located near the top left edge of the opening.
Aggiungi Commento
Flip your device right side up, and rotate it so that the optical drive is facing you. Insert a paper clip into a manual release switch located to the right of the automatic release button.
  • Flip your device right side up, and rotate it so that the optical drive is facing you.
  • Insert a paper clip into a manual release switch located to the right of the automatic release button.
  • Optical Drive will not release if you insert the clip diagonally. Make sure to insert the clip straight into the switch.
Aggiungi Commento
Gently pull out the disk drive until you can see the metallic case of the optical drive. Hold the metal case and continue to pull the drive out toward you.
  • Gently pull out the disk drive until you can see the metallic case of the optical drive.
  • Hold the metal case and continue to pull the drive out toward you.
Aggiungi Commento
Once you see the yellow labels on the disk drive, fully retract the disk mount until you hear a click. Once you see the yellow labels on the disk drive, fully retract the disk mount until you hear a click. Once you see the yellow labels on the disk drive, fully retract the disk mount until you hear a click.
  • Once you see the yellow labels on the disk drive, fully retract the disk mount until you hear a click.
Aggiungi Commento
Continue to pull the disk drive toward you until it is completely removed from the laptop's housing. Continue to pull the disk drive toward you until it is completely removed from the laptop's housing. Continue to pull the disk drive toward you until it is completely removed from the laptop's housing.
  • Continue to pull the disk drive toward you until it is completely removed from the laptop's housing.
Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
Cal Poly, Team 4-12, Maness Spring 2013 Membro di Cal Poly, Team 4-12, Maness Spring 2013
CPSU-MANESS-S13S4G12
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 59
Tutti i Tempi: 2,875
