Introduzione
Ordered a new battery? Have no idea where to start? Well don't worry, this guide will show you how. (Part number should be PA3534U-1BRS) Don't forget to dispose the old battery in an e-waste container.
Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you. Find the battery compartment. Slide the left slider which is just beneath the battery compartment into its leftmost position.
  • Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
  • Find the battery compartment.
  • Slide the left slider which is just beneath the battery compartment into its leftmost position.
Aggiungi Commento
Guida ai regali per la festa del papà
Facciamo onore non solo ai nostri padri — festeggiamo tutti i mentori che ci hanno insegnato a riparare.
Facciamo onore a chi ci ha insegnato a riparare.
Slide and hold the right slider into its rightmost position. Lift the battery out of the compartment. Do not touch the gold nodes inside the compartment. Do not touch the gold nodes inside the compartment.
  • Slide and hold the right slider into its rightmost position. Lift the battery out of the compartment.
  • Do not touch the gold nodes inside the compartment.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Grace Cowell
Membro da: 15/04/2013
268 Reputazione
2 Guide realizzate
Cal Poly, Team 4-12, Maness Spring 2013 Membro di Cal Poly, Team 4-12, Maness Spring 2013
CPSU-MANESS-S13S4G12
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 715
