Introduzione
Before attempting this guide, please have all required materials and tools. This guide is a long process and requires your full attention in order to properly replace it. When doing each step be careful and follow each step as listed.
Unplug the AC adapter and all other auxiliary components from the laptop. Slide the battery lock tab away from the center of the laptop to unlock the battery.
  • Unplug the AC adapter and all other auxiliary components from the laptop.
  • Slide the battery lock tab away from the center of the laptop to unlock the battery.
Aggiungi Commento
Slide the battery release tab away from the center of the laptop and hold it. Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  • Slide the battery release tab away from the center of the laptop and hold it.
  • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
Aggiungi Commento
Remove the screw holding the RAM cover with a PH1 screwdriver. Remove the RAM cover.
  • Remove the screw holding the RAM cover with a PH1 screwdriver.
  • Remove the RAM cover.
Aggiungi Commento
Push outwards on the metal tabs to release the RAM. Remove the RAM.  Some force may be needed. Be careful not to touch the gold pins on the RAM chips as there may be a build-up of static electricity.  This can fry the parts of the chip that houses memory.
  • Push outwards on the metal tabs to release the RAM.
  • Remove the RAM. Some force may be needed.
  • Be careful not to touch the gold pins on the RAM chips as there may be a build-up of static electricity. This can fry the parts of the chip that houses memory.
Aggiungi Commento
Use a PH0 screwdriver to remove the screw holding the optical drive in place. Using your index finger, push the metal tab inside the RAM bay which is located directly underneath the screw-hole. The optical drive will then slide out.
  • Use a PH0 screwdriver to remove the screw holding the optical drive in place.
  • Using your index finger, push the metal tab inside the RAM bay which is located directly underneath the screw-hole.
  • The optical drive will then slide out.
Aggiungi Commento
Unscrew the 4 highlighted screws with a PH1 screwdriver.
  • Unscrew the 4 highlighted screws with a PH1 screwdriver.
Aggiungi Commento
Orient the laptop so that the screen is open and facing you. Slide the plastic opening tool underneath the top edge of the black plastic insert. Pull it off and set aside.
  • Orient the laptop so that the screen is open and facing you.
  • Slide the plastic opening tool underneath the top edge of the black plastic insert.
  • Pull it off and set aside.
Aggiungi Commento
Remove the 2 PH1 screws. Lift the keyboard from the top being carful not to remove it fully. There is still a ribbon cable that connects the keyboard to the laptop.
  • Remove the 2 PH1 screws.
  • Lift the keyboard from the top being carful not to remove it fully. There is still a ribbon cable that connects the keyboard to the laptop.
Aggiungi Commento
Disconnect the keyboard ribbon cable and remove the keyboard from the laptop.
  • Disconnect the keyboard ribbon cable and remove the keyboard from the laptop.
Aggiungi Commento
Close the laptop and flip it over.
  • Close the laptop and flip it over.
  • Unscrew the 11 yellow circled screws with a PH1 screwdriver. These screws are larger in size.
  • Unscrew the 2 red and yellow circled screws with a PH1 screwdriver. These screws are shorter and thicker than the previous.
  • Unscrew the 1 green and yellow circled screw with a PH1 screwdriver. This screw is longer and thinner than the previous.
Aggiungi Commento
Flip the laptop over and open it so that the screen is facing you. Locate the hinges on either side of the screen, which secure the display to the body of the laptop. Unscrew the 2 screws in each hinge with a PH1 screwdriver.
  • Flip the laptop over and open it so that the screen is facing you.
    • Locate the hinges on either side of the screen, which secure the display to the body of the laptop.
    • Unscrew the 2 screws in each hinge with a PH1 screwdriver.
  • The display is no longer connected to the laptop and could fall. Be careful not to drop it during the next steps.
Aggiungi Commento
Unfasten the connectors from the highlighted locations. Disconnect by gently pulling on the fasteners which connect the wires to the laptop. Pulling directly on the wires could cause permanent damage to the connectors or the wires themselves.
  • Unfasten the connectors from the highlighted locations.
  • Disconnect by gently pulling on the fasteners which connect the wires to the laptop.
  • Pulling directly on the wires could cause permanent damage to the connectors or the wires themselves.
  • Unscrew the screw indicated by the yellow circle.
Aggiungi Commento
Slide the plastic opening tool underneath the edges of the upper casing, which is shown in the images. Slide the plastic opening tool underneath the edges of the upper casing, which is shown in the images.
  • Slide the plastic opening tool underneath the edges of the upper casing, which is shown in the images.
Aggiungi Commento
The LCD screen can now be removed from the laptop.
  • The LCD screen can now be removed from the laptop.
  • Lift the upper plastic casing and remove it from the lower half of the laptop.
Aggiungi Commento
Unfasten the two connections shown. Unscrew the two screws securing the fan to the laptop. Use a PH1 for the screw that is adjacent to the speaker and a PH0 for the other screw. Lift up the fan and pull the black plastic tab away from the fan housing. Remove the fan.
  • Unfasten the two connections shown.
  • Unscrew the two screws securing the fan to the laptop. Use a PH1 for the screw that is adjacent to the speaker and a PH0 for the other screw.
  • Lift up the fan and pull the black plastic tab away from the fan housing. Remove the fan.
  • Do not remove the metal fan housing. It is taped to a metal heat-sink and should not be removed.
Aggiungi Commento
First, remove the one screw with a PH1 screwdriver.
  • First, remove the one screw with a PH1 screwdriver.
  • Next, remove the black connector marked by the yellow box.
Aggiungi Commento
Gently pull the the small white ribbon cable from its housing on the motherboard. Locate and unfasten the small white clip from the motherboard near the bottom right.
  • Gently pull the the small white ribbon cable from its housing on the motherboard.
  • Locate and unfasten the small white clip from the motherboard near the bottom right.
Aggiungi Commento
Disconnect the two white fasteners that connect the speakers to the motherboard. Disconnect the two white fasteners that connect the speakers to the motherboard. Disconnect the two white fasteners that connect the speakers to the motherboard.
  • Disconnect the two white fasteners that connect the speakers to the motherboard.
Aggiungi Commento
Gently slide the plastic opening tool underneath and around the motherboard. Do not force the motherboard out. If the motherboard breaks, it is not repairable. You will have to buy a new one. After the motherboard is free of the plastic casing, do not pull it all the way out. There is still a connector on the underside of it.
  • Gently slide the plastic opening tool underneath and around the motherboard.
  • Do not force the motherboard out. If the motherboard breaks, it is not repairable. You will have to buy a new one.
  • After the motherboard is free of the plastic casing, do not pull it all the way out. There is still a connector on the underside of it.
    • Remove the connector on the underside using your fingers.
Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Devin
Membro da: 11/04/2013
30 Reputazione
3 Guide realizzate
Cal Poly, Team 17-5, Regan Spring 2013 Membro di Cal Poly, Team 17-5, Regan Spring 2013
CPSU-REGAN-S13S17G5
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 53
Tutti i Tempi: 5,913
